None restrictive dust filter
21 Jan 2017
County Durham
I've recently swapped out my in win 101 with a white version of the meshify C and upon reading up some owners review many people talk about the front foam filter clogging up and being tough to properly clean. After taking out the foam and seeing that it is more restrictive thank I though it would be I'm looking to pick up a decent front magnetic filter to replace this.
Do any of you kind folk know of any decent filters 360mm that don't hinder air flow much?
Yes, I used one. Temps increase 2 degrees when you fit one as opposed to having no filter, but nothing is completely unrestricted, otherwise the mesh would be large enough to let dust in. The temps also get hotter as dust builds up on the mesh, which can't be avoided.
Yeah I'm just looking for something that's better than the foam that's on there but the more unrestricted the better. I don't mind a little dust but I don't want to be cleaning it out every other week
