- 28 Jun 2017
Hi Guys
I'm looking to upgrade my first attempt at a simple watercooled loop, which works but look a little amaturish..... Like the look of the Monsoon MMRS system so I've put together the following basket ( I already have a CPU block, Rad etc):
Monsoon PETG Tubing 16/12mm (ID 1/2" OD 5/8") 4x90cm - Clear
Stock Code WC-303-MO
XSPC PETG Easy Cut / Easy Bend Toolkit
Configurator Monsoon MMRS Bundle
Your selected configuration: Edit Configuration
Reservoir End Cap 1 Monsoon MMRS Single Port End Cap - Black
Reservoir End Cap 2 Monsoon MMRS End Cap with D5 Pump Mount - Black
Fill Drain Port Caps Not wanted
Dual Bulb CCFL Lights Not wanted
D5 Pumps XSPC D5 Vario (Body + Screwring)
D5 Motor Mounting Cover Monsoon MMRS D5 Motor Mounting Cover - Red
Reservoir Mounts (2x) Monsoon MMRS Reservoir Mount 25mm - Matte Black
Temperature Plugs Not wanted
Tube Length/Colour Monsoon MMRS Acrylic Tube 100mm - Clear
Tension Rods Monsoon MMRS Tension Rods 100mm - Red
Plugs Monsoon MMRS Premium G 1/4 Plug - Chrome
Monsoon EV2 Compression Fitting For Hard Tubing 1/2" x 5/8" (15.2mm to 16.2mm) - 6 Pack - Red
Stock Code WC-454-MO
Mayhems Pastel - Red Coolant 1L
Will this work? Obviously looking to cool the CPU only- case is a Phantom 530
Any advice, comments encouragement gratefully received!
