Noob alert: How to "secure" my NAS/Network
18 Oct 2002
Kent
I put together my own little Xpenology NAS a few weeks ago and it was my first experience with proper home networking, i'd only ever setup a couple of routers before.
Being completely new to using Synology DSM and configuring both the NAS and connected devices i've had to follow a lot of guides as well as just blindly clicking buttons in order to setup DS Cloud Sync, Plex, Sabnzdb, Sonarr, Kodi etc etc.
My concern is that having made changes to permissions and opening ports in my router and allowing devices outside my network to connect to it (my brother's phone and laptop) I may have inadvertently left the NAS and/or the devices connected to it vulnerable. I thought i'd include a few screenshots of various settings i've changed in the process of trying to configure the NAS, installed packages, devices, router etc in case i've done some something obviously wrong.
Control Panel:
Typical Shared Folder Options:
File Services:
Control Panel > User:
Typical User Settings:
Control Panel > Group
Control Panel > Network:
3JvlJlT
Control Panel > Info Center
Control Panel > Web Services
Router Port Forwarding (this was for Sab and Sonarr i believe)
Ok so that turned out to be a lot more screenshots than I thought i'd do, hopefully someone might given them a quick glance :)
Any other general advice would be most appreciated.
Thanks
i see you opened 5000 as a http service, and also enabled https but didnt do the port forward for it, i would change 5000 to 5001 and change the protocol from all to tcp
Removing the port forwarding rule should be enough.
Do you need local web access to the unit?
All i was looking to do was setup DS Cloud/Sync to run on my brother's iPhone and laptop in order to sync a folder for photo's and whatnot. I'd like to allow him access to my Plex server too but that's of secondary importance.
Yeah I wouldn't open the web admin login myself if I could avoid it, I have port forwarded a few things but not the ability to logon to my NAS and change anything that way.
