Noob: Comp build help
Cool, so if they come with converters then DVI is better bcoz its more enhanched graphics? what exactly does tv out do.
Not really, the quality of VGA will be the same through a converter or directly from the VGA socket. If you could find an AGP card with dual DVI id be impressed. I wouldnt pay over 20/30 quid for a decent AGP card. Depends what your going to be doing on the machine.
Chances are it will be VGA & DVI, my Radeoon 9600 had this.
Id just forget about TV out, it was really bad and fuzzy picutre. If you have an LCD TV, most have VGA or DVI/HDMI inputs on them which will work much better.
