noob how-to questions about
22 Oct 2002
Near Cheltenham
I only dabble in linux, mainly for tweaking my QNAP NAS etc..
Since I've just got an embedded linux Media Streamer, I've needed to do a couple of things that elude my knowledge, and google isn't giving me digestable answers.. So if any kind soul could help..
1. 'joining' Directories - Something I've used Junctions for in windows, but I want to join two directories together to aggregate their contents into a read only pseudo directory? Can I do this? Or perhaps I'm remembering incorrectly, maybe I need to symlink every sub directory from both folders into my pseudo folder? In which case how do I script that? Can it be done, i.e. a 'for every folder in x..'
2. In a startup script, I want to wait until the network adapter has got an IP address (As I want to then mount some network shares to some local directories).. I use mount -t cifs //server/share /local_folder -o,username=x,password=x in a startup script, but currently, I have to use a 'sleep 60' to make sure the wireless dongle has been picked up and connected before running the mount commands.. if I could easily script it so it waits for the connection (say checks every 6 seconds upto 20 times) then it should be a bit more efficient..
Thanks..
1. Are they separate drives? I'd use LVM in this case.
2.
Code:
#! /bin/bash
main()
    ping -c google.co.uk > /dev/null
    if [ "$?" -eq 0 ]
    then
    else
        echo 'waiting..';
	sleep 15
	main
    fi
main
2.
Code:
#! /bin/bash
main()
    if [ "$?" -eq 0 ]
    then
        echo 'waiting..';
		sleep 15
		main
    else
    fi
main
Thanks Mike :) I'll see if I have access to lvm in this embedded version, it sounds exactly what I need from googling it!
Have you looked at unionfs? That's what I would use. LVM won't do what you want, you'll need to reformat etc, and it's just not made for that... and symlinks are ugly as hell.
Do you use networkmanager? In that case have have a look at the dispatcher in /etc/NetworkManager/dispatcher.d, all scripts in there get executed in alphabetical order with $1 = adapter name $2 = up or down. Write a small bash script for the appropriate cif mounts/umounts in both cases.
If you don't then it can be more tricky, but i'm not going to get into huge details you probably wont need!
