- 4 May 2011
Hi everyone, Ive been reading through as many threads as possible on these boards to try and get a rough idea on what the best components for my budget are and have decided upon a build. However, i would just like some confirmation that the build is the best bang for my buck and that it'll all work together.
My Budget: £600ish (Can go slightly over if its worth it) to buy everything, that includes a Monitor, speakers, mouse, keyboard and wireless network card (Dont need a windows 7 licence). I currently have a laptop which is slowly dying and im not going to make the same mistake again and buy a laptop when i can get a much better desktop which i can keep up to date with upgrades.
What im aiming for: A PC which can play any game on the market today, im not always looking for being able to play it on maxed out settings.. Just after a PC which will play them with a decent framerate and fairly good graphics. Im also trying to make the build as upgradable as possible, so i can keep buying new things for it over time.
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor with FREE Operation Flashpoint Red River Game £149.99
(£124.99) £149.99
(£124.99)
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black BenQ G2222HDL 21.5" Widescreen LED Monitor - Black £102.12
(£85.10) £102.12
(£85.10)
Asus P8H67-M Pro Intel H67 (Socket 1155) DDR3 MicroATX Motherboard - (Sandybridge) ** B3 REVISION ** Asus P8H67-M Pro Intel H67 (Socket 1155) DDR3 MicroATX Motherboard - (Sandybridge) ** B3 REVISION ** £89.98
(£74.98) £89.98
(£74.98)
Sapphire ATI Radeon HD 5830 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** Sapphire ATI Radeon HD 5830 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** £85.99
(£71.66) £85.99
(£71.66)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £43.99
(£36.66) £43.99
(£36.66)
G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBXL) G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBXL) £35.99
(£29.99) £35.99
(£29.99)
OcUK Zeus Tower Case - Black (450W PSU) OcUK Zeus Tower Case - Black (450W PSU) £32.66
(£27.22) £32.66
(£27.22)
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
(£14.99) £17.99
(£14.99)
OcUK Value 300Mbps Wireless-N PCI Adapter OcUK Value 300Mbps Wireless-N PCI Adapter £12.98
(£10.82) £12.98
(£10.82)
Logitech S-150 2.0 USB Speaker System - OEM (980-000029) Logitech S-150 2.0 USB Speaker System - OEM (980-000029) £11.99
(£9.99) £11.99
(£9.99)
Blaze K3285 Multimedia Slim USB Keyboard - Black Blaze K3285 Multimedia Slim USB Keyboard - Black £7.99
(£6.66) £7.99
(£6.66)
OcUK USB Optical Mouse - Black OcUK USB Optical Mouse - Black £2.99
(£2.49) £2.99
(£2.49)
Total : £622.50
This is what ive decided on at the moment but i have never built a PC before so im abit cautious about afew things. Ive decided upon a case which includes a 450w PSU but im wondering weither that PSU is good enough or weither its something you shouldnt try to get cheap. Also the graphics card, is that good enough or should i be looking for something different?
I also havent included any extra fans for the case in that budget but are they required or will the supplied case fan be enough for my needs?
Thanks in advance!
a happy noob!
(£124.99) £149.99
(£124.99)
(£85.10) £102.12
(£85.10)
(£74.98) £89.98
(£74.98)
(£71.66) £85.99
(£71.66)
(£36.66) £43.99
(£36.66)
(£29.99) £35.99
(£29.99)
(£27.22) £32.66
(£27.22)
(£14.99) £17.99
(£14.99)
(£10.82) £12.98
(£10.82)
(£9.99) £11.99
(£9.99)
(£6.66) £7.99
(£6.66)
(£2.49) £2.99
(£2.49)
Total : £622.50
Thanks in advance!
a happy noob!
