- 22 Apr 2011
- Nottingham
Hi all.
I have oc'd my N580 to 900/1800/2150 @ 1.1V, This seems stable with max temps around 75c Furmark, 70c Gaming.
The question I have is in GPU-Z in sensors it says:
VDDC Current 8.0A (Idle), 45-48A (Load(Furmark))
Is this the Amps its pulling down the 12V rail? I was considering SLI but seeing as my PSU only has 60A on the 12V rail its no where near enough?
Do I need a PSU with ~90-100A on the 12V rail to run 2 N580s at the above oc'd speed? Or will they both not draw 45-48A each under load when in SLI, Is it drawing so much because its a single card?
Sorry for the noob questions, Help appreciated guys.
Cheers
Cheers
