Hope someone can help me get my head around what settings I should be using to test OCing my rig. I've been reading up on this all day, but it's confusing the hell outta me as this is my first time at it.
Here's my setup...
Asus P5w-DH Deluxe with BIOS 2302
E2200 with stock cooling (until I get round to getting something better)
4 GB of Corsair XMS2 5400
Currently according to CPUZ it's all running at 200.8 x 11 = 2208, with a Rated FSB of 802.8MHz (although I don't get what the Rated FSB part means yet). The Core Voltage shows as 1.280V... I guess this is the value I may need to change as I increase the FSB and RAM values..?
I gather I'm supposed to set the RAM to run at a ratio of 1:1 with the CPU, which I do by setting it to twice whatever the FSB is....? So, does this mean that I should be determining my FSB in terms of what my RAM is capable of? If so, how can I work out how far I can push the RAM, so that I can then determine what the FSB will be? Or should I be working out my FSB first, and then doubling that in order to get the RAM setting?
Sorry if this is uber-noobish... but I'm an OC virgin
Here's my setup...
