Right so below i will list my OCs i have done on this rig so far and hopefully one of you can tell me how to sort it ...
Stock
CPU Speed: 3.415 GHz
Multiplier: x17
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 30
Load Temps: 45 (½ Hour Prime Blend) Alt 0189
CnQ: On
Voltages;
AOD: 1.35V
CPU-Z: 1.280V
3Dmark06: 15303
SM 2.0 Score: 6265
SM 3.0 Score: 7057
CPU Score: 4195
Over-clock #1 (½ Hour Prime Blend Only)
CPU Speed: 3.615 GHz
Multiplier: x18
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 36
Load Temps: 50.5 (½ Hour Prime Blend)
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.376V
3Dmark06: 16115
SM 2.0 Score: 6445
SM 3.0 Score: 7334
CPU Score: 4711
Over-clock #2 (½ Hour Prime Blend Only)
CPU Speed: 3.716 GHz
Multiplier: x18.5
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 36
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
3Dmark06: 16287
SM 2.0 Score: 6486
SM 3.0 Score: 7387
CPU Score: 4868
Over-clock #3 (½ Hour Prime Blend Only)
CPU Speed: 3.817 GHz
Multiplier: x19
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 36
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
3Dmark06: 16443
SM 2.0 Score: 6514
SM 3.0 Score: 7419
CPU Score: 4996
Over-clock #4 (½ Hour Prime Blend Only)
CPU Speed: 3.917 GHz
Multiplier: x19.5
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 31
Load Temps: ## (½ Hour Prime Blend)
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
3Dmark06:
SM 2.0 Score:
SM 3.0 Score:
CPU Score:
Over-clock #5 (½ Hour Prime Blend Only)
Multiplier: x19.5
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 31
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
Bios: 1.425V
3Dmark06:
SM 2.0 Score:
SM 3.0 Score:
CPU Score:
So test 1, 2 and 3 all run fine on a 30 min Prime 95 Blend this was done more to establist Temps over stability ... im naturally aiming for that magic 4Ghz stable overclock as so many people out there are and a lot are finding it to so i just hope i can
System Specs:
CPU: AMD Phenom II x4 964 C3
MOBO: ASUS M4A785TD-V EVO
RAM: 2x2GB OCZ DDR3 1333Mhz ram
GPU: Saphire 5770 Vapor X
PSU: Corsair 650W TX
CPU Cooler: Freezer 7 Pro Rev .2
So yea any ideas would be much apreciated basically the only thing irly tried is upping the multiplyer and tht worked up to 3.8Ghz without any Voltage boost but now at 3.9 and hopefully 4.0Ghz im gonna need some more Volts or maybe a faster NB speed i dont know rly thats why im here i guess
Thanks
TonkV8
Stock
Multiplier: x17
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 30
CnQ: On
Voltages;
AOD: 1.35V
CPU-Z: 1.280V
3Dmark06: 15303
SM 2.0 Score: 6265
SM 3.0 Score: 7057
CPU Score: 4195
Multiplier: x18
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 36
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.376V
3Dmark06: 16115
SM 2.0 Score: 6445
SM 3.0 Score: 7334
CPU Score: 4711
Multiplier: x18.5
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 36
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
3Dmark06: 16287
SM 2.0 Score: 6486
SM 3.0 Score: 7387
CPU Score: 4868
Multiplier: x19
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 36
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
3Dmark06: 16443
SM 2.0 Score: 6514
SM 3.0 Score: 7419
CPU Score: 4996
Multiplier: x19.5
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 31
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
3Dmark06:
SM 2.0 Score:
SM 3.0 Score:
CPU Score:
Multiplier: x19.5
FSB: 200
HT Link: 2000
NB Multiplier: x10
Idle Temps: 31
CnQ: Off
Voltages;
AOD: 1.35V
CPU-Z: 1.4V
Bios: 1.425V
3Dmark06:
SM 2.0 Score:
SM 3.0 Score:
CPU Score:
System Specs:
Thanks
TonkV8
