Noob Question - Converting \n into an actual list
16 May 2004
Near Chester
Hi,
Have been interrogating google on this one and can't seem to quite find the answer to help and hopefully this is a nice easy for someone in the know to help get my head around how to do it quickly!
I have string of data with the line breaks within the text which is been output as follows;
\nUnrecognised item: Extra Vegan Cheese, Plant + Chips\nUnrecognised item: No Vegan Chipotle Mayo, Plant + Chips\nUnrecognised item: No Chipotle Mayo, Fritter + Chips
However, i want to quickly and easily format it as;
I am trying to do this is copying it into Notepad ++ and pretty sure it can be done using find and replace but i'm obviously not quite getting it right. If i can do this in another tool I am happy to use something else!
Thank you for any help
Notepad++ should be able to do it. Make sure you select the "extended" radio button in the search/replace dialog, then search for \\n and replace with \n
You need the double \\ in the search.
That is great, bang on what i needed!
Thank you for taking the time to answer this as was driving me mad!
