Noob question :D
  • Thread starter Thread starter Kyo
  • Start date Start date
Kyo
Kyo
11 Oct 2003
Hi
I was wondering, I am currently using a gtx580 (for the time being) and it is coping with my 24" tn panel running natively at 1920x1080. My query is if I switched to a 27" tn panel that natively runs at the same resolution does that mean the graphics card should do the same amount of work as the 24" or does it not work that way because it still more pixels in the bigger panel?
Thx
Kyo
Thx for the quick reply (surprised u are up this early) :)
So in other words the 27" just has bigger pixels compared to the smaller tn.
