Noob question on AMD 144 overclocking capabilities and pedigree.
19 Feb 2006
:confused: I'm new to all this, rarely finish a crossword and the likes. Please can someone shed some light on my predicament?
I've rushed out (carefully researched) and bought loads of goodies (pc bits) to the tune of £1,500.
I've bought an Opty 144 thinking I can become an overclocking guru...
Guess what?
I've just accused myself of not doing my homework as it's arrived with a CAGE ref (not cacje, cabne etc).
I've looked all over the tinterweb to see what on earth this chip is capable of... NOTHING. Not a sausage.
Can anyone help?
Has any one seen this one before? Should I bin it and get a 146? If so which is the stepping to look out for?
Just try it. Information about steppings and overclocking can only be taken with a grain of salt anyway because even with the so-called great overclocking steppings, there can be some turkeys.
You could have a legendary chip there or it could be crap. Just give it a shot.
Are you sure your not just reading the wrong part of the CPU for the stepping?
Any chance of some pics to confirm its a CAGE?? :confused:
only steppings i've heard of are
CABNE
CABYE
CAB2E
CABGE
Big.Wayne said:
Is that your opinion or is that a fact? hard to tell?
Both the very early CABNE or CABYE 0540 are the best opty 146 clockers.
Fact.
Nearly all CABYE 0540's will do 3ghz on air.
with the CABGE steppings being the worst.
Thanks for helping me out so far.
Here is what it says on the chip:
AMD Opteron (no suprise there)
OSA144CEP5AT
CAAGC 0428WPMW
1067458G40073
On the box:
osa144atbox
It says its bin loc is: s07E (CAGE)
Have I a prehistoric chip here, I dunno. I'm dying to find out what it'll do though. All my other bits arrive today...
bettyswollocks1 said:
Thought so. Thanks. I'm off to kick my cat around the house for a bit and then order another that fits the bill. Trouble is I think I'll find the good ones next to the rocking horse sh** box.
the new 3700+'s seem to be doing ok... might be worth a look if you cant find one you want.
