noob question on bathch processing RAW
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
I have 66 RAW files, need to just simily save them to Jpeg. Is there anyway to do it all in a row without manually opening and saving each one?
If you have CS2 just select all the files in the browser section and open them all, then select all the thumbnails on the left hand side in the raw window that opens up then save them all from there.
SCM
SCM
excellent :)
