Noob Question sorry!
Don
5 Oct 2005
Liverpool
How do I get this line to insert the number??
int PriKey = (AdminGridView.Rows[e.RowIndex].Cells[0]).insert here;
I can't for the life of me do this, for example if I wanted text I would put...
string PriKey = (AdminGridView.Rows[e.RowIndex].Cells[0]).Text;
Stelly
p.s. sorry sorry sorry
Try This:
Code:
int PriKey = int.Parse(this.AdminGridView.Rows[e.RowIndex].Cells[0].Value);
TrUz
TrUz said:
Try This:
Code:
TrUz
not there I mean this...
'System.Web.UI.WebControls.TableCell' does not contain a definition for 'Value'
Stelly
protected void AdminGridView_RowDeleting(object sender, GridViewDeleteEventArgs e)
int PriKey = int.Parse(this.AdminGridView.Rows[e.RowIndex].Cells[0].value);
SQLQueries.InsertDeleteLog(PriKey, TimeStamp, UserName, BookedFrom, accessed);
like this... and I know its not finished :)
Stelly
Ahhh Web Application, sorry try this:
Code:
int i = int.Parse(this.GridView1.Rows[e.RowIndex].Cells[0].Text);
TrUz
Hmmm, does for me. What error are you getting now? What kind of Data is in the grid?
TrUz
TrUz
what you mean?? few integers and strings thats about it... I cant see anything wrong with it to be honest... help :)
Stelly
Do you have the Edit, Delete and Select buttons on your Grid? If so the Cell index is going to be 1 not 0.
I have just tested with this and it is fine.
Code:
        protected void GridView1_RowDeleting(object sender, GridViewDeleteEventArgs e)
            int i = int.Parse(this.GridView1.Rows[e.RowIndex].Cells[1].Text);
            Console.Write(i.ToString());
EDIT: Might be worth using row deleted. Just incase there is a problem deleting the row you will fill your delete log with false deletes.
TrUz
Code:
TrUz
are you sure?? if so oops.. I mean they are on the end of the data row though
Stelly
My Edit, Delete items etc... was in the first column. If it is the first column (0) that has you item then I am not sure why it is not working.
TrUz
