Noob question
14 Jun 2009
North East
Looking at building a new system, but just wanting to make sure certain things will be compatible, primarily the RAM and CPU
CPU:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-365-IN
RAM:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-205-CS&tool=3
My concern is the channels, processor says dual channel, am I right in thinking it won't be able to support triple channel RAM? or am I miles wrong?
The last time I built my system, there was nothing even remotely as complex as these issues, so wanting to make sure beforehand.
Correct, that cpu is 1155 socket. Means it fits in motherboards with a 1155 socket too :p All said 1155 motherboards have chipsets that only support dual channel ram
depending on how heavily you use photoshop and 3d modelling, you might be better off looking for 8Gb of ram rather then 4Gb ;)
I'm thinking 8Gb to futureproof myself, and also I'll be doing more PS and 3DSMAX on a machine that can handle it.
Current one does the job, but has started to fall over and die on occasion.
