Noob Question...
Aye, they won't come with any cables.
If you bought your motherboard in a retail box then it should come with some SATA data cables (though if your motherboard was an OEM version or came with a pre-built system then it likely won't). If you need new SATA data cables, these are the ones I would go for.
As for the power connections, your PSU should come with some SATA power connections. If there are not enough left then you should use these.
