Ok I don't know the first thing about ram.
I am wanting to get some ram for this motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-349-GI
Was thinking
http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS&groupid=701&catid=8&subcat=1517
Will it be compatible?
Reason I ask is because says on the product page
Quote
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
End Quote
I need 8gb ram
I have a budget of £170 inc the motherboard I listed. So will take alternative recommendation. Basically want the best bang for buck MB/Ram combo. My cpu is phenom 965 BE and intend to replace this next year with a bulldozer.
Thanks for yer help.
ps I have a Thermaltake frio so ram clearance is minimal.
Was thinking
Quote
End Quote
I need 8gb ram
I suspected as much just wanted to check.
