i) How high is too high?
ii) Is it normal for one core to run up to 7C hotter than the other?
I'm getting 56/63 at stock under full load and that's much hotter than any CPU I've had and monitored before. Winding my case intake and CPU cooler (which doubles as case extract) fans up to max only drops the temps to 56/61 - just 2C on just one core going from minimum fan speed (1100 rpm) to maxium (2000rpm).
In any case thouse temps are very poor, the 4 pipe dual core stock AMD cooler would perform better than that Evo there (im not joking
Havent seen or read any review of said cooler since it hit retail; which was quite a while back now tbh. Did it have 'Dual Core supported' stamped on box or maybe instal manual, if not then...
