Noob Questions
13 Nov 2012
Welling
Hi guys, in 2014 I did my first build with a custom loop and I will be swapping cases soon as my current case is a bit too big. I am going for the Fractal Design Define C as this is the most compact ATX case I could find but im not sure if my radiator/pump/res will fit in. Also what coolant would you guys recommend and is there any maintenance/cleaning I will have to do as I haven't touched it in 3 years. Thanks
Components -
Case - Corsair Air 540
CPU - Intel 4670k
Mobo - Gigabyte Z87X-UD3H
GPU - EVGA GTX 780
RAM - 8GB Corsair Vengeance Pro 1866mhz
PSU - Antec High Current Gamer 750W
SSD - Samsung 840 EVO 250GB
HDD - Western Digital Green 1TB
Watercooling -
Alphacool Nexxxus XT45 240mm
EK Supremacy Clean CSQ
EK DCP 4.0 Pump Res Combo
Bitspower Matt Black Fittings
Okay, I can't comment on the case.
Maintenance: You will need to take apart the cpu block and give that a serious clean up.
A good flush out of the rads will be needed as well just to be sure. I'd go with the Blitz cleaning products that Mayhems provide.
The rads will need as much dust cleared out as possible so that will be worth a look.
Other than that I try to stick with either the X1 Mayhems fluids or Distilled water (with dye) will work with a silver kill coil.
Depends on your aesthetic preferences.
