- 10 Sep 2009
- What are timings all about? I see CL7 and CL9 mentioned a lot, which is fastest?
- Basically what are you looking for when you buy RAM? All I know is that DDR3 is the fastest. I also know about Dual Channel and Tri Channel.
I'm having trouble deciding on which RAM to get for this motherboard (MSI P55-GD65)... it says this about memory:
the choices of RAM are;
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz
vs
Geil Ultra Series 4GB (2x2GB) PC3-17000 2133MHz
Now, I think the Geil RAM wins, because it's 2133MHz, and the GD65 motherboard says it supports 2133- but you must overclock for it. I will attempt to overclock.
Or am I wrong, is the G.Skill better?
- Memory: 4x DDR3 DIMM 2133(OC) / 1600 / 1333 / 1066 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
vs
