Noob to sli need advice
8 Nov 2008
UK
Ok I have a EVGA GTX 460 superclocked 768mb. Card
Would it be possible to get a 460 1gb and sli them or do i need to have to identical cards?
Also would it be worth it? or would I be better of just upgrading to a 560?
Would the upgrade be worth it?
I am heavy gamer and run duel monitor setup. (only use one monitor for gaming)
And no I wont touch ati every single card I had from ati has been faulty or had driver issues.
If I was in your position I would get a new card with more VRAM and sell your current one.
+1
@nuttyprot
It won't work 768 with 1GB mate, it has to be the same cards with same amount of Memory on them.
I had SLI with 2x460 768 MB - rubbish mate,Better buy one card with more Memory on it.
In Benchmarks they were awsome, but when gaming not ;)
@nuttyprot
ty for the advice I have few ideas what 560 I want so going with that cheers all.
Just to give you some other options I picked up the card in my sig for £270 and performs solid in BF3 on Ultra settings.
Could be worth looking into that tho does depend on your budget.
