system is from OC and i believe i have this watercooler in it, Asetek 120mm 570LC High Performance Compact Solution Gen 4
http://asetek.com/desktop/cpu-coolers/570lc/
what i would like to know:-
how do i check the water level the item is solid black no visible water level?
how do i fill it if i needed too?
thanks
thanks
