Noob Triple Rad Question
17 Nov 2011
Hi All
Just installing new WC build and not sure sequence for Triple Rad and 3 Silent eagle Fans 2000. Do i put the fans between rad and roof and use long screws or screw fans to rad and then screw rad to top of case also whichever way i do it does the fans blow into case or out of the case. Sorry if seems daft question
:cool:It's all up to you as it will make very little difference. I have my 360 pushing air out of the case, so everything else stays cool and if you have a rear fan, set it to intake so the cool air will be exhausted through your rad, thus improving temps marginally.
:p;):D
Edit: Added crimbo smilies because I can :D
:p;):D
feeling festive? :D
Yeah it doesn't matter whether you go push or pull - just do whatever is easiest for you buddy. I'd go pull, to prevent nasty dust build up!
Hi Guys
Thanks for answers think i will go pull on the rad so will fit fans on barb side sucking air through rad and use rear fan as exhaust. Think its gonna be a late night lol
Hi Guys
:D I was up till 4 on Thurs night putting my other 580 back into the loop. =D
