Noob watercooling setups please
15 Mar 2006
Vancouver, BC
Ok guys I have been fiddling around for PC's for a few years now but I have never ventured into the world of water cooling. I would like some suggestions on what to use to cool my rig thats in my sig please.
Depence what you can afford. I went for swiftech and haven't looked back since ;)
Ok cool thanks a lot for the advice, it looks like the 120 kit would suit my needs well as my case has a few 120mm fans in it already.
Chronictank said:
if you follow the instruction guide the RAD is mounted outside the case so it shouldnt be a problem
I mounted my rad outside the case which made things for me A LOT easier. Just have a drimmel and the rest is easy
Ok well I do not have a dremel but fitting it outside of the case makes it sound a lot easier than queezing it inside.
