5 Dec 2010 at 11:12 #1 coughs coughs Associate Joined 9 Aug 2010 Posts 710 If I wanted 2 or 3 loops to cool my overkill system will it require 3 of everything pump, rev etc? sorry if its a silly question this is my first wc build
5 Dec 2010 at 11:20 #2 Martini1991 Martini1991 Caporegime Joined 18 Sep 2009 Posts 30,542 Location Dormanstown. I think you're confusing the word loop. A loop consists of rad(s)/pump(s)/res(s)/block(s). A loop is just what's running in that "circuit". I assume you mean multiple rads, in which case you can fit multiple rads into a loop. But, what are you trying to cool? It'll give the more experienced better information to go on.
5 Dec 2010 at 11:35 #3 mjones1 mjones1 Soldato Joined 4 Jan 2009 Posts 4,145 There is no point going dual loop really since single loop gives the same temperature and costs less.
5 Dec 2010 at 12:19 #4 coughs coughs Associate OP Joined 9 Aug 2010 Posts 710 TJ07 Case 360 rad at the top and quad at the bottom I am cooling 990X with SLI 580's
5 Dec 2010 at 12:27 #5 JeffyB JeffyB Soldato Joined 10 Feb 2006 Posts 4,071 Location London I'd dual loop a setup like that, tripple for the cpu and quad for the 2 gpu's.
5 Dec 2010 at 12:28 #6 oldbag oldbag Soldato Joined 14 Oct 2003 Posts 7,831 At first I read the topic as "Noob Waterboarding" - I need to wake up.
5 Dec 2010 at 12:47 #7 coughs coughs Associate OP Joined 9 Aug 2010 Posts 710 So do i need 2 pumps and stuff if i'm going to have 2 rads?
5 Dec 2010 at 13:41 #8 mjones1 mjones1 Soldato Joined 4 Jan 2009 Posts 4,145 coughs said: So do i need 2 pumps and stuff if i'm going to have 2 rads? Click to expand... If you want to go dual loo, yes you will need two pumps. Give this a read first before you make your mind up
5 Dec 2010 at 14:03 #9 Martini1991 Martini1991 Caporegime Joined 18 Sep 2009 Posts 30,542 Location Dormanstown. coughs said: So do i need 2 pumps and stuff if i'm going to have 2 rads? Click to expand... Nope. As long as it's good enough.
5 Dec 2010 at 14:37 #10 coughs coughs Associate OP Joined 9 Aug 2010 Posts 710 Does anyone know if you can put a 260 rad in the front of a TJ07 Case aswell?
