Hi,
Please be gentle with me here. Basically I have built my first system and it appears that one of the HDD's is probably duff. Before going through the RMA proces I have been asked to run some diagnostics on the HDD (a Samsung spinpoint 250) to confirm it is faulty. The utilility software can be found at:
http://www.samsung.com/Products/HardDiskDrive/utilities/hutil.htm
The instructions tell me that I will need to create a boot CD or Floppy to carry out the diagnostics. Presently the floppy I do have installed on my new machine is not working for some reason, so I am left with no choice but to create a boot CD. The problem is I haven't got a clue on how to do this, despite several trips round google and trying different things.
I haven't got much to work with either. The only machine I have at home is an aging Gateway PC running windows 98. It has a Plextor CD RW and I have WinOnCD ver 3.7 for burning CD's.
Could some one out there give me an idots step by step guid on what I need to do to create Boot CD that can run the uitlities detailed above? Is the PC I'm using up to the job?
Any help much appreciated.
Thanks,
Jubbly
Thanks,
Jubbly
