Hi all, just took delivery of a XFX HD5770 card from OC (cheers!), with the intent of using it in Crossfire configuration with the Powercolor 5770 I've had for a year or so. However the box seems to lack a Crossfirex interconnect. Does Crossfirex no longer need the interconnect? (I saw some newer models no longer have the 'golden fingers' edge connector, although both 5770s here do have 'em) or should I have expected to see an interconnect cable in the XFX box? If the latter, I guess I'll need to get in touch with OC support, as I can't seem to find anywhere I can buy an interconnect on it's own. (unfortunately I can't seem to find the older Powercolor box, to see if it had an interconnect)
Thanks in advance.
Spadge.
Thanks in advance.
Spadge.
there are places that sell them seperatly, failing that, check the well know auction site, loads on there.
