- 13 May 2003
Ok
I have an Abit AV8 motherboard and I have a Coolermaster case with two front mounted USB headers.
I'm fairly sure I've attached the wires correctly to the mobo but I can't get the USB ports to work.
On the bios I have enabled all the likely looking options.
Is there an obvious mistake I might be making?
