nooo, homeworld 2 wont work :_(
Permabanned
11 Mar 2004
just re installed it after a few months, i try to start it up, it spins up my cd for a few seconds, pops the process in the task monitor then just stops and drops off the taskmon :(
the games been patched and has worked perfectly fine before?? :( i hope its not because of the new graphics card, i love this game so much that i would consoder changing it. new cards an HIS X1900XT 512 crossfire master card by the way, although its not running in crossfire...
pieman109 said:
have you tried reinstalling the game and not patching it? worth a try I'd say.
got to patch it for multiplayer. if your not at the same version as others online you dont get to play with them. :(
i tried using a no cd exe to see if it would run and it did, so i switched back to the original exe and its now authenticating my cd and running but wont let me join multiplayer games :( grrrr :mad:
Ummm silly question, do you have a firewall? ie: Zonealarm? becuase homeworld 2 will only run when i turn mine off for some reason????
I had a few problems with the resolution, this was due to my 20" WS monitor not liking it. Just a thought, mind.
titaniumx3 said:
If you have a router try enabling or disabling UPnP. I can remember having to fiddle with this when I first played HW2 multiplayer.
tired that :(
Behemoth said:
I had that problem too, then realised I hadn't ran Windows Update in a while, I did so and bingo all was fine after that :)
i cant understand how that would have any effect :confused: :(
