nooooooo order rejected!
Absolutely sure you entered your card details correctly? Any chance of using someone elses card?
You could also try dropping OcUK an email and call them in the morning. IIRC you have until lunch time before the This Week Only offers change.
SiriusB
hi
I would try again in the morning, and if that fails (double and triple check your card details), ring the store.
I think the "this week only" offers tend to change sometime after midday.
i've had my card rejected after I've ordered and TWO's have changed.
A simple email got them to reput my order through with last weeks two items i ordered at the right price :)
I've had that happen when the details entered don't match that registered to the card.
Have you moved house or has your postcode changed?....
Ring OCUK and they can tell you where the process failed, or at least they did when i put my new post code in and it didnt like it.
yer I've recently moved house, possibly that has something to do with it :( I might hold on for a while, just had that feeling last night that I needed to spend some money :)
