Nord VPN bricked my internet, please help
25 Nov 2005
Installed the latest update which caused internet to stop working, have tried uninstalling Nord, recycling router, restart PC, a system restore, reset network settings, the usual commands in CMD
I can get internet to work on start up for about 30 seconds or when I recycle the router but then it stops working again, can't for life of me figure out how to fix this issue, it's definitely something the Nord update did though as I had the same issue a few days ago but a simple restart fixed it
It's basically like killswitch is on, but it shouldn't be and it won't even let the app connect
Have a look for the additional gubbins that nord installs in control panel like the network tap. I had a similar issue with the desktop version.
