Normal Temps for this setup?
27 Oct 2009
Hi all
First time OC'ing, and first PC build in a few years.
Rig setup:
i7 920 D0
Asus P6t SE
Scythe Shuriken HSF
Corsair XMS3 6GB 1600
Antec 300 case
Nvidia 9800GT
All I have is the case fans (1 top, 1 back) and the CPU Fan...I dont want to add anymore becuase even on Low setting it's louder then I want it to be.
Anyhows, just got it installed with Win 7 Ultimate 64. Updated the BIOS, left everything stock and I am getting idle of around 45c, Prime95 load tops out at 68cish.
3.3Ghz OC (FSB 166 iirc) and idle is 55c, load around 80c
3.9Ghz (FSB 186 iirc...) and idle is 58 but load reaches 95c+ (I chickened out and closed the stress test after it hit that in under 1 min)
These temps seem on the high side to me - not sure what ambiemt room temp is, but idle 9800GT with stock fan is 45c.
Case is nice and clean (brand new...) and no cables in the way. I was under the impression this was a decent HSF, 99% sure its not something like a mis-seated Heatsink as I checked that over a good few times.
Any ideas? Is this just a crap HSF? What are my "safe" temp ranges?
Note, I rarely push my PC to full load often, if at all for any extended period. I just want to OC it for 1)fun 2)higher steady clock rate
Thanks in advance.
Thank you, shame I bought the wrong HSF, its brand new as well :x
I will try a Mugen 2 soon - any idea how loud this is compared to the Shuriken?
Half tempted to try watercooling....damn noise is grating on my nerves.
Welcome to the forums :)
It's also quite crap. There's good reason why all the air cooling people are running thermalright ultra 120 extreme / megalahems / corsair H50, these processors are astonishingly hot.
Unfortunately you're using a case with very light, thin side panels and holes everywhere. This is never going to be quiet unless everything inside it is just about silent. Some cases can cut down noise a bit, it just happens that the antec 300 can't.
Watercooling is an excellent answer for silencing computers. I'm running an 8800gt and a 920 D0 under water, and a frankly badly assembled loop is keeping the processor at 4ghz, 60 degrees is is certainly quiet. Fans are at 12V until I bother to sort out a fan controller and it's still quite reasonable, dropping them to 7V means I have to strain to hear it at all. It'll cost you a significant amount of money though, and will probably involve a new case. That's not the end of the world, the antec 300 is pretty nasty.
Cheaper approach, and probably the better one, is to get a good air cooler and change case to one of the antec P180 family. You can likely run the cpu heatsink fanless if you wish, as there's a 200mm fan above it and a 120mm fan just behind. It depends how fanatical you want to get really. You can have two of fast / quiet / cheap, watercooling is the first two, aircooling is fast/cheap, and quiet/cheap is the world of dog slow atom systems and the like.
Other than case/cooling that's a well thought out system. Just unfortunate that you've discovered noise annoys you, doesn't seem to bother everyone but drives me mad as well.
Thank you for your reply Jon :)
Wow, I made some really bad choices I thought were "good"...
I'll be honest, I will not end up getting a new case - its all brand new and I just cant bring myself to do it....BUT :D
Xmas is coming, and everyone always complains I am hard to buy for...maybe I could get people to chip in for different parts of a watercooled system! What a great idea :D
How expensive am I looking for a watercool kit/parts that will suffice? There's so many kits, that frankly, all look the frickin same but some cost loads more. How much do I really need to spend, and what if I want to watercool my 9800GT as well? The stock fan on that is quite loud.
The only other choice I have and have really thought about it getting the best air coolers regardless of noise levels, slap in extra case fans (front, side) and have one huge lawnmower of a PC. Stick it under the stairs (which is next to me) and close the door. It stays astonishingly cool under there for some unknown reason - Just not sure if it will heat up too quickly with a PC running in that space.
I've got an antec 300 with all fan slots filled...
Yes, its quite noisy, but you soon get used to it. I barely even notice it anymore....
Maybe i've gone deaf from all the noise? Who knows.
It's a nice case, the thin side panels make it lighter, and also means its great for case modding. lots of people have added their own side viewing plates and things. Since its brand new, i doubt you want to be doing this either. I just think its a nice case, cheap, big, lots of fan space. Only downside as people say is that its noisy.
Speaking of which... tempted to get a new case. Storm Scout is tempting me...
It is a nice case in every other way, I agree. Well built, etc.
When I'm really stuck into my work I dont really notice the noise. But its when Im trying to watch a film at night, its impossible to do it without the volume too loud becuase Im straining to hear over the fan noise!
EDIT: Kids in bed etc..
