Normalisation help please
17 Apr 2003
hOme
yes i know its college work and i should do it but i think i know what the problem is i just need it confirming
im designing a database to store info on all my songs and here is the normalisation i have come up with:
which i have been told is correct, but when i come to set the database up in access with the relationships:
i get an error when i try and put an entry in the remix table like this:
i think this is because the vinyl and cd yes/no attributes are primary keys in their own tables and not in the remix table, but i cant see any way of getting round it :( do i have to split the remix table into 2 seperate ones?
any advice much appreciated :)
I dont know anything about normalisation except in the maths/physics sense, but you seem to have spelt 'Artist' wrong in the first pic :p
Wouldn't affect the relationships of the database.
I see normalisation and switch off, I never understood what I was doing when I was doing it and when I was doing it I never knew if I was doing it right.
It would be like the blind leading the blind. Do you have the Connolly and Begg book? Database systems? ISBN 0-201-34287-1.
Covers normalisation well in there but I think its one of the fields in access you've defined. Check the properties of the fields in vinyl.
I know the people that wrote that book, they were my lecturers at paisley university and one of them, thomas used to work for the company i work for now graham technology, im reading that book again this week while im off to refresh my mind on db's, might be able to help you in a few days, small world lol.
Primary Key
Foreign Key
Code:
Artist	[U]ArtistID[/U]
	Artist
CD	[U]CD_ID[/U]
	CDWalletPage
	DateAdded
Vinyl	[U]Vinyl_ID[/U]
	DateAdded
Song	[U]SongID[/U]
	[I]ArtistID[/I]
	SongName
Remix	[U]RemixID[/U]
	[I]SongID[/I]
	Remix
	Duration
	Key
	[I]CD_ID[/I]
	[I]Vinyl_ID[/I]
Your relationships look correct, but I'm worried about what the ? is for in your "CD?" "Vinyl?" fields. No CD or Vinyl would be signified by not having an entry for the foreign key, i.e. CD_ID = NULL, not by a "Yes/No" field. Therefore by using CD_ID you don't (I think) need "CD No" as they would be the same thing?
Incidentally, you appear to have lost Genre somewhere along the line.
Helium_Junkie said:
Primary Key
Foreign Key
Code:
	Artist
CD	[U]CD_ID[/U]
	CDWalletPage
	DateAdded
	DateAdded
Song	[U]SongID[/U]
	[I]ArtistID[/I]
	SongName
	[I]SongID[/I]
	Remix
	Duration
	Key
	[I]CD_ID[/I]
	[I]Vinyl_ID[/I]
good point about genre - thanks :D
CD? and Vinyl? are yes/no boxes
some tunes can be CD or Vinyl, or both, so there is always going to be a value (yes or no, ticked or not ticked) but i honestly dont know whats going on, access doesnt seem to want to update the cd and vinyl table from the remix one
thanks for all the help so far guys :)
This is not the way it should be done. Yes/No boxes which then link to another table makes my head hurt. Change the Yes/No to a foreign key. Then if your remix is on a CD you put a key in. If it isnt, you dont. Same general purpose as the tickbox, but with the link to the CD/Vinyl all rolled into one.
Otherwise how would your CD table link to the remix? In what you've put down there is no shared key in those tables other than a tickbox - which means your primary key in a table has two possible values, and therefore you can only ever have 2 rows in that table! It makes me think that perhaps you're picturing having lots of seperate CD/Vinyl tables, one for each remix... which is not a normalised approach.
You are trying drag a null value across from the CD or Vinyl field from its respective tbl but you cannot as the record does not exist, its got to be Y or N.
Or to put it another way....
you are pulling 2 values across into Remix when you have only entered 1 value.
Change the table proprties of the fields:
CD_ID
Vinyl_ID
to not required.
Smiley Man said:
pfft typos dont mean anything :p
yeah i know its so damn confusing, i thought i had it then access started getting in a flap :mad:
It is NOT a typo; it is a nineteen years old DJ who doesn't know the difference between an artist and an artiste trying to pass off their ignorance as a typo.
its a typo god damn it :mad: :D
so if the box isnt ticked its a null value? right that makes sense, will give it a go now
What?
The typo was "Atrist", not "Artiste" ... what are you talking about?
I'm telling you, having a yes/no as a key is wrong. Stop and do it with a proper alphanumeric ID!
Your error message at the top is probably because you've tried to link to a vinyl but you havent first created the vinyl in the table. You can stop that error by adding two fields to Vinyl, one ticked, one not.
Do you really intend your database to only ever hold data of one vinyl and one CD?
^^ Also, sit down and think about what you are storing and why. That will give you the field names needed. Then, forget about logical thinking and do what the 3 rules say, take each field one at a time and then apply the rules....
Smiley Man said:
so something like:
1 - cd
2 - vinyl
3 - both
thanks :D
Stop thinking of it from the remix table point of view, and look at the Vinyl table.
How many vinyls do you want your database to hold, one? or Many.
If one, then sure a tickbox is fine.
But if you want more than one vinyl in your database you need to delete that evil tickbox and change the ID of the Vinyl to a number, just like the artist table, the remix table, the song table...
Current possible fields in Vinyl table:
Yes - Number - Date
No - Number - Date
-------- thats it, your primary keys are used up, you can never again have a vinyl.
