Northbridge cooling
20 Oct 2004
Alright guys
What do you lot generally find to be the situation with northbridge cooling?
My Asus P5N-E has passive cooling and I'm hoping to take my E6600 up to around 3.4-3.6ghz, or at least somewhere close to that. Will I need to stick some kind of fan onto the NB to keep it cool? Is it likely it will need a little extra voltage?
From experience, does it often need tweaking?
If so can you just get screws that go into metal and screw on the fan to the heatsink that way?
Cheers
