- 29 Aug 2010
- Cornwall
It seems like all I do on these forums is ask questions. Sorry about that!
Anyway, here we go again.
I've got a Gigabyte 880GM-UD2H running a Phenom II X6 1055T overclocked to 3.8GHz. Now I'm not good with overclocking so I bought the pre-overclocked bundle from OcUK. Correct me if I'm wrong but the northbridge gets overclocked along with the other thing right?
I'm planning/hoping to have the cpu and gpu water-cooled but I didn't think about the northbridge so that'll be left with the default cooling.
When I initially started the PC up with air cooling (Titan Fenrir) to check it worked (before I fitted all the water stuff) I noticed in HWMonitor that the 3 temps it gives (not the cores) were about 60C on the cpu and what I'm guessing was the northbridge after only a minute of Prime 95. (admittedly I didn't have much airflow through the case, as I had the side of the case off.
What sort of temps can the northbridge run at safely?
