Northbridge Fan
On the bottom? You mean behind the motherboard? It's possible, not really useful but you can do it. If you mean on the bottom of the case where the feet are, that would totally screw up airflow. And if you mean on the side panel, also screw up airflow. If you want better NB temps then get this, an HR-05 or an N881.
Not really, i can't imagine it would be much better than your stock one. Either get one of the one's i said before or the Noctua NC-U6.
On my old Socket A motherboard I mounted the fan from an old Radeon 9800 Pro over the northbridge. :)
Now however I've got an asus p5n-d which already had a heatsink and fan attached.
