Norton Ghost Question
6 Jul 2006
England, Stafford
im wonder weather i should get Norton Ghost beucase i am getting a new laptop and have a bad habit of filling them up with rubish and i am wanting to know if Norton Ghost will be able to create a backup up of my drive as soon as it out of the box so i have a clean version. and will it be easy to restore to the orinal way. i.e just like it was when i bought it. also is it easy to access file on a full system back such as if the laptop got nick would i be able to access my recesnt file if i back them up easly with out the orinal computer
thx
ali
Ghost is perfect for this sort of thing.
As for your recovery to a newly installed OS, you can make a set of recovery CDs that you can boot off and restore from; like all the large OEMs do.
You will need to remember of you are doing regular backups, thats your images are going to get really quite big. For that sort of backig up I would suggest a program taht cn do incremental and differential backups, liek Windows backup.
Burnsy
When I got my lap-top "Out of the Box" from Multi Vision (now out of business) there was loads of stuff in the Temp Files, Cookies, IE Cache etc, (presumably from installing the modem and other drivers).
Multi Vision put a restore system on the hard drive, Drive C and the remainder of the programs on Drive D (My Drive D is everyone elses C). I've only once restored it to its "Out of the Box" state. When I did it after a few well minded warnings it showed a screen "Norton Ghost" and it worked a treat. The only thing of course, all the stuff in Temp, Cookies etc was back on the computer and I had to remove them again.
You will not have that problem, if you get rid of the junk before installing Ghost!
