Norton Systemworks replacement suggestions?
24 Jun 2006
Hi all,
After decided Norton is crap, does anyone have any suggestions on what I can replace the WinDoctor part of Systemworks with? Got a virus scanner and firewall but something that can clean up the registry, missing files, etc etc would be nice.
Any thoughts?
Ta :)
Paul.
system tools 5 (think its called that)
edit:// heres the link http://www.systemtools.com/
although there was a open source freeware product that was quit good ill try find it
also i think you can type scanreg /fix in run but im not shure if it werks on xp it did in 95 and that will fix ** registry
Tuneup utilities 2006 is what ive been using for quite a while since i also fell out of love with system works does what it says on the tin so to speak had no problems with it whatsoever :)
Another vote for TU2006. Also came from Norton SW :(
