- 24 Jun 2007
Hey peeps,
Right, I have a fan on the side of my case that draws air into my case. This fan came with my case and it lights up blue.
Anyway, this fan itself doesn't seem to be loud exactly, I believe it is the actual airflow of it. For instance, when I cover the fan up (with my hand or shush) my case is considerably quieter. Now is there any way I can reduce this noise somewhat? Like I say, it seems to be the airflow, so I aren't sure if I can.
I could unplug it all together as it doesn't seem to cool my case any better (actually seems to make it a few degree hotter) but I do like to have it lit up blue.
What could you suggest?
Jamie.
Jamie.
