Hi,
I've been burning the midnight oil for the last year earning some bucks so decided to treat myself. As such, I have no clue that’s the current sweat spot; AMD or Intel, Nvidia GT, GTS, GTX, but it seems the following may be a good start.
I currently have a KT400/XP2500/GF4-TI system that is in need of an update (I try to get my moneys worth). Im planning on keeping my Coolermaster 201* because its such a nice case but it does limit the length of the PSU hence the below. Ill also have to check the size of the cooler.
The PC most intensive tasks will be code compilation, some CAD work, simulations but occasional I play games (well not in the last year but I reserve the right to
) and encode multimedia hence the quad core; is this best bang for buck?
I don’t plan to overclock and a silent PC is preferable but a compremise is OK.
Parts:
Akasa Ultra Quiet 500W Paxpower Active PFC ATX2.2 PSU - Black Nickel
http://www.overclockers.co.uk/showproduct.php?prodid=CA-024-AK&groupid=701&catid=123&subcat=239
£53
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-131-AB&groupid=701&catid=5&subcat=913
£82.24
Intel Core 2 Quad Pro Q6600
http://www.overclockers.co.uk/showproduct.php?prodid=CP-172-IN
£156.26
OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
http://www.overclockers.co.uk/showproduct.php?prodid=MY-072-OC&groupid=701&catid=8&subcat=813
£36.41
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR&groupid=701&catid=57&subcat=821
£17.61
Asus GeForce 8600 GTS 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=GX-126-AS&groupid=701&catid=56&subcat=912
£103.39
Sub Total: 448.91
Im wondering if the following is worth it:
...for an extra £66.37 I could get abit more graphics power:
Point of View GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=GX-015-PV&groupid=701&catid=56&subcat=1008
£170.36
...or for an extra 36.41 I could get an extra 2GB or RAM.
My original budget was 400-500 but I could easily stretch further - just don’t want to ***** money up the wall if it’s not going to yield much.
) and encode multimedia hence the quad core; is this best bang for buck?I don’t plan to overclock and a silent PC is preferable but a compremise is OK.
Parts:
£53
£82.24
£156.26
£36.41
£17.61
£103.39
Sub Total: 448.91
£170.36
I could wait but Id probably just end up waiting and waiting and never get around to it due to new hardware always being around the corner.
