Hi all, my first post here so please be gentle.
I'm one of those reads a lot but rarely do. Well finally I did go out and put together a system with a budget of £1k (tower, contents, including windows).
Here it is anyways:
the 2500k is OCed to 4.6 @ 1.38v (peaks 1.392 sometimes). Temps are more than adequate.
Everything else is stock clocks (mem/gfx).
Now the path I want to go is as follows:
Now I'm pretty sure I'm able to fit 2x GFX cards and the sound card across the PCI slots on this mobo and everything else should plugin fine so I chose ok on the mb I believe. By the way I'm getting a second card because I'm pushing games to a 27" screen at 2560x1440
-My question is I guess can the PSU support all this? Or how much of it can it do?
There are loads of threads that say a 650w can support the xfire (I doubt I need to OC the cards for a couple of years). But this is a bronze PSU.
-Would it be able to handle the rest, keeping my 2500k at 4.6ghz?
Here it is anyways:
- Get another HD 6950 2GB to XFire
- Get one of those funky lcd fan controllers, mostly for novelty factor but I also want to be able to monitor things whilst a monitor isn't plugged in.
- Get a SSD to use as enhanced cache for the 1TB 6GB/s
- 2x 2TB 3GB/s in RAID 1 with each other
- Decent ish sound card for output
