Hey,
So I decided to finally clean out my PC a bit today and also change my 2 X 1gb sticks of RAM to dual channel - they were right next to each other before.
So did all this, tried to switch them round when tower was upright.. didn't work too well.. they would go in but i could easily pull them out.. they seemed in the right position - and as before I moved one of them.
Booted.. did its usual, power up 5 secs, reboot then it powered up but the CPU fan just went on and on highish power settings (does this ususally but only for a few seconds) with nothing on the screen.
So I unplugged everything, laid the case down and tried to reseat the ram properly.. did that and I still get the same result. Pretty sure it was seated correctly.
Any ideas? My specs in my sig.
CHeers
CHeers
