Not convergent in sqr05
Man of Honour
12 Feb 2004
Herne Bay, UK
SuperPI gives me this error when trying to run 2 instances even @ stock speeds anyone else had this problem ?
thanks for info :D
Asus P5N-E-SLI
2Gb OCZ Platinum Revision 2 XTC
C2D6300
7800GTX
Tagan 530 Modular
X-Fi Fatality
i've had it running @ 3Ghz and didnt find any problems at all running everything fine and a good 2 hour session on COH last night saw no problems
just thought i'd have a play today and got that error so i decided to put it all @ stock and it still does it :confused:
You definetly got the voltage at stock?
I know my board undervolts, so you need to set it higher in bios than you think.
well i set the voltages in the bios too
CPU = 1.35
RAM = 2.1
NB = 1.5
and it just ran 2 instaces fully :D
must be undervolting i guess :confused:
now back to 3Ghz to see if it still works then
I'll let u know ;)
