www.steventhomson.co.uk
So, that's my incomplete website atm. It's based on a heavily modified template which uses CSS, and it doesn't display properly in Firefox, only in IE. Even the original template, it seems, doesn't display properly in Firefox, and I don't actually know any CSS, so I'm stumped. Is there any way to fix it? I've been using a WYSIWYG editor, and haven't been playing with the code, so it's all a bit beyond me.
I'm not looking to put too much effort into this, seeing as its more of a placeholder design than anything else, just until I can find the time to sit down and design one from scratch, and maybe learn some programming. If it can be done, then great, but if it's going to take a lot of work, I'll junk this template and start again. And I know there are some redundant links on the page, I'll get rid of them later.
The CSS source can be found here - http://www.steventhomson.co.uk/images/BrightSide.css
(the template was called Bright Side, hence the URL)
I've also just this minute noticed that clicking the XHTML and CSS buttons at the bottom of the site throws up a whole host of errors (such as 'no style sheet present' in Firefox) but, as I said, I don't understand the language used, so I can't fix them.
Can anyone help?
Thanks
tTz
Can anyone help?
Thanks
tTz
