I bought a OcUK Crusade 850W PSU a month or so back but miss-read the spec.
I am fitting my PC with 2x 5850 gfx cards which both need 2x 6pin pcie power connections.
The PSU only has 2x 6pin pcie connections which means I am 2x short
The PSU has 4 other cables as follows:
2x 4pin molex (one cable has 3x molex plugs, the other has 2x molex)
2x sata (both cables have 3x sata plugs).
Could I use each of the molex cables (using 2x plugs on each cable) with the following molex to 6pin pcie adaptor or do I need to use two seperate molex cables with a single adaptor (4x molex cables each connected to an adaptor)?
I plan on using the 2x sata power cables to power my DVDR (1 cable) and 2x HDD (1 cable).
