Not enough memory to duplicate
25 Jul 2004
Hi Everyone, I am using Dantz Retrospect to duplicate one drive to another. After the software scans the drives, an error appears reporting that there is not enough memory to complete the job.
I can't afford to buy any RAM at the mo, so what options do i have?
Thanks, Phil
Try some of the following:
Killing as many background apps and processes as possible. Even better if you can run the software in Safe Mode.
Reinstall the software
If that fails, try looking at the help section for a troubleshooter.
Failing all the above try different software for the job :D
SiriusB
