Not enough VRAM
16 Jan 2013
New tomb raider minimum requirements 2 gb of VRAM. I only have 1.2 bg. Is there any tweaks I can make. If not what will I be missing. Gameplay wise. Thanks
"DirectX 11 graphics card with 1GB Video RAM, AMD Radeon HD 4870 or nVidia GTX 480"
Don't know where you got 2Gb from..
VRAM requirement will be proportional to Resolution/AA/Texture quality anyway - as long as you have the minimum spec card required can't see what the issue will be - if it doesn't perform then turn stuff down
Minimum Spec is as follows:
• DirectX 9 graphics card with 512Mb Video RAM:
AMD Radeon HD 2600 XT
nVidia 8600
Recommended is as Rossi listed
http://www.polygon.com/2013/2/22/4016874/tomb-raider-pc-system-requirements-revealed
I can confirm after measuring VRAM usage on release day that @1080p, TR fully maxed out used up to 1.6GB on my rig. A 2 GB card will do it, as will it do pretty much most games other than Skyrim with a load of mods and crysis 3
