Not entirely sure where to put this but Xbox live connection query.
26 Apr 2004
Milton Keynes
Im currently using a wireless network, connected to the internet via a router.
I have just got an xbox in my room, and would like to be able to try out the free trial of Xbox Live I have.
I have an nforce4 ultra motherboard with the LAN capabilities onboard, so was hoping to connect my Xbox to Live, by plugging the ethernet cable from my Xbox, to my wired lan port on my PC, so it can connect to the internet I recieve wirelessly by my network. Is it possible to do this, and if so can someone explain to me how to set it up, or do you need to plug the Xbox directly into the router?
Thanks,
Alex
It's possible, though your mileage may vary. All you need to do is bridge the two interfaces (select both, right click, bridge).
