Not happy with psu.
31 Dec 2011
Hi,
Am in the process of building a pc. I've taken some parts from an older i5 set-up. The one thing that is troubling me is the PSU, it's an OCZ 600 Stealth X Stream and it is clogged up with dust, a lot of it I can not remove. Because of this, I'm very wary of it.
I think it would be better to replace it, price range would be about £80 to £90.
The rest of the set-up is as follows:-
Phanteks Enthoo Pro
Maximus V11 Ranger mobo
Intel i7 4790K
8mb Crucial Ballistix Sport.
Will be looking at the overclocking at a later date.
Would appreciate any advice given.
Can you not get a compressor or a hefty air-duster in there to clear it out?
If you're not worried about warranty or anything, perhaps you could take the casing off and clean it properly?
Would try and change to a new PSU if possible - older stealthxstreams had a habit of degrading quite fast so that after 2-3 years their max power output and stability underload wasn't anything like as good as it should be.
Thank you all.
Think I will go with the SuperFlower. As for the OCZ I have at the moment, it is getting a little long in the tooth, must be about 4 to 5 years old, so I think its due to bee retired.
Thanks again all, got to admit the forum has a wealth of information.
