Not postiing
22 Jul 2006
Hi all,
Brought my incar PC into the house to upgrade to a better spec, with the idea of using the old as a file server.
Ok so 2 problems:
Now with the old spec inside a case, it will not post at all - the fans spin up but nothing else
2nd problem is with the new system, after a while it will decide to just freeze, and in need of a hard reboot.
Any ideas on the 2 problems?
Thanks
Give us more to work with, can you type up the specs.
Also a incar pc??? Im trying to picture it but I can't. Please go into more detail on what you had setup, im intrigued :)
